no power to these fuses
Old Jun 22, 2016 | 01:47 PM
it8kurmojo's Avatar
13 air bag , 15wiper , 16 HVAC, 19 EPs....... fuses good ... also radio was ripped out I have since replaced the radio ,radio has power but won't turn on ...p0650 mil code ...purchased the car at auction please help....2006 hhr LT
Old Jun 22, 2016 | 02:13 PM
Welcome to the site!
Seems some wiring may have been damaged when the radio was removed.
As for the P0650 code have a thorough read they this thread
http://www.obd-codes.com/p0650
And check the ground wires, per
https://www.chevyhhr.net/forums/how-...cations-56504/
Also check power to the power outlet, if there is no power there the OBD II port will not have power, should be as you got the code pulled!
Then you can dive into the fuse box under the hood , they work loose sometimes, use the search window it links to Google
Old Jun 22, 2016 | 03:15 PM
You cannot just plug any radio into a modern car! At least, you need an adapter so the car doesn't think it's stolen.
I assume you are talking about the BCM (inside) fuse box.
So, here is an idea: check the underhood fuse box
They supply the BCM
Here is my alternate guess: Somebody tried to hot wire the car and blew a few wires up. All of those fuses connect to the "hot in run or start" circuit.
Old Jun 22, 2016 | 03:20 PM
And if it is a GM radio you installed you will need it coded to your vin , you will need the bin from the original car for the radio, I believe this has to be done at a GM dealership
Old Jun 22, 2016 | 06:34 PM
it8kurmojo's Avatar
Thanks for the info people, going to work on it tonight ,I did install a stock gm radio I guess it needs to go to a dealer to get unlocked . I haven't repaired the antenna connection to the radio yet, it was cut clean off, is it also a ground?.. and yes the car was stolen , it came from a impound auction
Old Jun 22, 2016 | 07:02 PM
Ahh the plot thickens! Let us know what you find!
roberttx
Sep 23, 2021 07:48 AM
skywatcher
May 30, 2015 01:57 PM
dfornet
May 31, 2012 08:27 AM
Davyo
Tires & Wheels
10
Aug 30, 2011 03:35 AM
da_dad66
2.2L Performance Tech
0
Apr 8, 2008 08:03 PM
