Noise very much like a bad wheel bearing
Old Dec 9, 2019 | 08:06 AM
The end play tolerance is 0.015 inch! If you can sense any looseness it is bad. That's 3 times.
I have installed a bad bearing out of the box, defects are possible.
Old Dec 9, 2019 | 08:24 AM
So the one with the play you explain is the one that requires replacement. One pothole, or train tracks can damage a bearing hub.
Old Dec 9, 2019 | 08:49 AM
You say you Haven't replaced the control arms yet. Looking at the diagram, it looks like a worn ball joint could possibly allow the 12 to 6 movement you're describing. Maybe it's also causing the geometry to be so wrong that the hub is howling?
Old Dec 9, 2019 | 09:23 AM
Lethal Tendencies's Avatar
Brand of wheel bearing? Mileage on wheel Bearing? Does the noise lessen when you hit the brake pedal?
Old Dec 9, 2019 | 03:11 PM
Blue_SS's Avatar
So true!
I see this in warranty every month. Pothole damage or similar. The price you pay for lightweighting and low purchase price....
Old Aug 30, 2020 | 03:56 PM
Sundance's Avatar
Did you ever find out what the cause was? I am having this very problem myself on a 2010 HHR with 135K miles.
Old Aug 30, 2020 | 06:41 PM
If it sound like a hub, it probably is a hub.
If you really care you should start a new thread that includes your particular symptoms since this one was nebulous.
Old Aug 30, 2020 | 07:22 PM
Sundance , I just replaced front hubs, that cured a lot of noises and squeals. I bought PowerStop hubs from RockAuto. Very good quality part.
Old Aug 30, 2020 | 09:50 PM
Sundance's Avatar
Originally Posted by donbrew
If it sound like a hub, it probably is a hub..If you really care you should start a new thread that includes your particular symptoms since this one was nebulous.
If it sounds like a hub it probably is a hub? If I really care? Start a new thread to add to the myriad of threads to make searches even more difficult? .Impressive..
Oldblue, thanks for your help.I am hoping Kenny Webster will reply with the solution to his problem..
Old Aug 30, 2020 | 10:55 PM
Of course, you ignored the rest of the sentence. All we have to work with is somebody said they had a noise that sounded like a bad hub. If some particulars had been supplied there may have been help.
"Having this very problem" really says you don't care much. What is the nature of this problem? Just how is your problem exactly like "it sounds like a hub" Did you follow any of the suggestions offered? Kenny Webster will not be back, because he was banned for being obnoxious.
