Odd noise
I have a 2008 2.2L and for the past couple days I have been hearing an odd noise..now its kind of hard to describe, it sounds like a motorcycle, or as a kid if you used to put playing cards in your bicycle spokes... it gets louder when you go faster. So i thought it was a tire that was low so i filled it up and checked the other 3 and all seems to be ok. It only seems to be doing this noise when the car is in Drive. If i put it in neutral or park and rev i dont hear it. It is really noticeable on decelerating.
any ideas? thanks |
So it's something when the wheels are turning. Make sure you don't have any foreign objects hung up around one of the wheels and rubbing.
On the mechanical side, may be a bad CV joint. |
so hopefully that sound description helped haha and i thought of a nail but none seen..ive never had a cv joint go bad on me before so I have no idea..ill take another look tomorrow morning for something being stuck in there somewhere
You can try jacking each corner up and spinning the tire by hand. With the front tires, also test with the wheel turned in and out as well as straight ahead.
Would a cracked flex pipe sound like that? I have not experienced it myself but from the conversations I have read on here that was the first thing I thought of. Seems if the flex pipe was cracked it would only sound like that under load.
wheel bearing -.-
Funny..I also get this howling noise when I'm really getting on it....weird too as it only happens it when the wife is in the car..........
Now that is funny son......My car does the same thing when the lovely wife is along...........:lol::lol:
What a coincidence.. Same thing here w/ wife along, & I don't even have to be getting on it..
I turn the radio up louder..It helps..:D |
Originally Posted by IgottaWoody
(Post 689796)
