Odd noise
Old Jan 28, 2013 | 04:44 PM
skyline26's Avatar
Odd noise
I have a 2008 2.2L and for the past couple days I have been hearing an odd noise..now its kind of hard to describe, it sounds like a motorcycle, or as a kid if you used to put playing cards in your bicycle spokes... it gets louder when you go faster. So i thought it was a tire that was low so i filled it up and checked the other 3 and all seems to be ok. It only seems to be doing this noise when the car is in Drive. If i put it in neutral or park and rev i dont hear it. It is really noticeable on decelerating.
any ideas?
thanks
Old Jan 28, 2013 | 05:14 PM
So it's something when the wheels are turning. Make sure you don't have any foreign objects hung up around one of the wheels and rubbing.
On the mechanical side, may be a bad CV joint.
Old Jan 28, 2013 | 05:20 PM
skyline26's Avatar
so hopefully that sound description helped haha and i thought of a nail but none seen..ive never had a cv joint go bad on me before so I have no idea..ill take another look tomorrow morning for something being stuck in there somewhere
Old Jan 28, 2013 | 05:39 PM
You can try jacking each corner up and spinning the tire by hand. With the front tires, also test with the wheel turned in and out as well as straight ahead.
Old Jan 28, 2013 | 07:14 PM
VinceP's Avatar
Would a cracked flex pipe sound like that? I have not experienced it myself but from the conversations I have read on here that was the first thing I thought of. Seems if the flex pipe was cracked it would only sound like that under load.
Old Jan 30, 2013 | 11:22 AM
skyline26's Avatar
wheel bearing -.-
Old Jan 30, 2013 | 11:43 AM
IgottaWoody's Avatar
Funny..I also get this howling noise when I'm really getting on it....weird too as it only happens it when the wife is in the car..........
Old Jan 30, 2013 | 12:38 PM
Now that is funny son......My car does the same thing when the lovely wife is along...........
Old Jan 30, 2013 | 01:17 PM
What a coincidence.. Same thing here w/ wife along, & I don't even have to be getting on it..
I turn the radio up louder..It helps..
Old Jan 30, 2013 | 07:05 PM
VinceP's Avatar
I dont hear it so much in the HHR. Now when I get the Vette out there are a few more high pitched noises.
Barry Herbert
Aug 21, 2014 10:16 PM
Gsus
Sep 6, 2013 08:42 AM
sumo1
Aug 11, 2009 07:27 PM
vschriver
Jun 20, 2008 09:09 AM
HHR321
Feb 17, 2007 11:18 AM
