Odd transmission issue
My 07 panel has sat the last 3 months (I broke my leg). I go to drive it today for the first time and it will not shift out of 1st and is slipping. No check engine light. I just replaced the fluid and filter last year. No leaks. I haven't checked the fluid yet, but like I said I haven't seen any leaks. If I rev it high it will catch but not shift. Any thoughts?
Any sign of varmints chewing on wires?
If it has been sitting in the same spot any fluid loss would be in a puddle under the car. And not the cause of failure to shift. Could be the solenoids froze up . |
Originally Posted by donbrew
(Post 947426)
The ground to the TCM shouldn’t be required, instead check continuity
Don't do that stupid FB ground wire thing. It is dangerous and un needed. If the TCM ground is bad just fix it; there is a wire in the connector that grounds it.
Didn't see any chewed wires yet. I did the ground mod though lol. Tomorrow I'm going to add a quart of Lucas to the trans and see if that has any affect on it. If not it's being sold cheap lol. This was just a extra car, I really dont need it.
https://cimg0.ibsrv.net/gimg/www.che...1dc2144bc4.jpg
Found the problem. Speed sensor wiring was chewed through 🤬 |
Varmints 1, HHR 0.
| All times are GMT -5. The time now is 02:04 AM. |
