Oil & Coolant leak
Old Sep 12, 2019 | 12:36 PM
  #31
This tool?
Old Sep 13, 2019 | 12:17 PM
  #32
mobilebyrd's Avatar
I can't get the bolt out.
I've tried both 18" and 24" breaker bar and even a 1/2" electric Ridgid impact gun (manual says 2,250 in lb)
The bolt won't budge and I'm applying enough force with a breaker bar that I'm moving the engine and am concerned the pry bar wedged in the balancer will bend or let loose.
Old Sep 13, 2019 | 03:11 PM
  #33
The torque wrench isn’t the tool to use as a breaker bar.
I used my 1/2 drive 24 “ breaker bar and the handle from my HF aluminum jack for an extension of leverage
Old Sep 13, 2019 | 04:25 PM
  #34
My cheap HF air gun did mine.
The spec is 74 ft. lb. + 125 degrees. that translates to something like 180 ft. lb.
I guess that means that it has been off before and replaced by King Kong.
Old Sep 13, 2019 | 04:40 PM
  #35
Definitely replace that crank pulley bolt.
Old Sep 13, 2019 | 04:47 PM
  #36
Blue_SS's Avatar
This is great advice. Once you get it out...
Old Sep 13, 2019 | 04:51 PM
  #37
Blue_SS's Avatar
OP, if it's an auto, make sure it's in Park. Manuals should be in 5th gear (and wheels loaded if you can).
Both increase the engine's resistance to just turn, and should help you loosen it...
Old Sep 13, 2019 | 06:37 PM
  #38
mobilebyrd's Avatar
I I only use the torque wrench to confirm that 125 foot pounds wouldn't break the bolt free.
I have a new bolt, washer, & seal but can't get that bolt off.
Old Sep 13, 2019 | 06:38 PM
  #39
mobilebyrd's Avatar
Thanks.
It's an automatic and was in park.
Old Sep 13, 2019 | 06:59 PM
  #40
You need a better impact gun. Trying to turn against the bolt with just a wrench is only going to allow the crankshaft to turn before it breaks loose. The impact gun has the advantage of "rattling" it loose so to speak.
Learned this lesson the hard way on several things over the years. Tried to take some blades off a bush hog deck one time. 1 1/4 nut wouldn't budge with a 4 ft cheater bar. Impact gun with 150 psi behind it got it off.
