Oil Leak
Old Sep 12, 2016 | 02:50 PM
guppy's Avatar
Oil Leak
2008 HHR 2.2L 54K
I discovered a few drops of oil on the driveway. I thought it was coming from the oil filter cap, so I replaced the O-ring. Next day still new drops appeared. I cranked the car up and noticed a little pin hole on the oil filter cap, so I replaced the oil filter cap with another used one that I had in the garage off of a 2.4L. I inspected it's O-ring and it looked good and pliable. I took a paper towel and wiped all the excess oil off the top of the engine. So I figured the oil leak is now fixed. I drive to work, 15min on the interstate and when I get to work I pop the hood and discover oil on top of the engine again. Any ideas of known oil leak spots up here?
http://i96.photobucket.com/albums/l1...R/IMG_0966.jpg
http://i96.photobucket.com/albums/l1...R/IMG_0965.jpg
http://i96.photobucket.com/albums/l1...R/IMG_0964.jpg
http://i96.photobucket.com/albums/l1...R/IMG_0963.jpg
I am at work and can not go out and look at it. It is driving me crazy.
Old Sep 12, 2016 | 02:58 PM
Valve cover gasket, oil fill plug oring
Old Sep 12, 2016 | 04:18 PM
A brand new cap is only about $5, last I looked. They used to be available "everywhere car parts are sold". Oil pressure sender is under there.
Old Sep 12, 2016 | 05:08 PM
Oil pressure sending unit. Take a look at that.
Old Sep 12, 2016 | 09:21 PM
The funnel like oil filler tube was a leaker on mine! I forgot I just removed it, and just use the cap.
Old Sep 13, 2016 | 01:11 PM
guppy's Avatar
The leak is not coming from the valve cover or the funnel oil fill neck. It is impossible to see the oil sending unit, but I snapped a picture.
I cleaned everything up real good and I am off to work.
Old Sep 13, 2016 | 02:19 PM
Based on your picture, I would say it's not the oil sending unit that's leaking.
Old Sep 17, 2016 | 04:26 PM
guppy's Avatar
Finally got some daylight time to further investigate and could not find the source of the leak. So I retightened the oil fillter cap, it turned maybe 20°. It is now extremely tight, especially for something with an o-ring in it. I used engine degreaser and cleaned EVERYTHING. Engine looks like new. Drove it a couple days and no leak, must have been seeping from the second oil filter cap.
Old Sep 17, 2016 | 06:13 PM
Keep us posted, we like a clean engine bay!
Old Dec 2, 2016 | 06:36 PM
guppy's Avatar
Was driving to work today and smelled burning oil. I immediately pulled over and killed the engine, there was about a quart of oil puddling up on the ground below my engine. Popped the hood and the top of the engine is covered with oil. I have no idea where it is coming from (maybe around the oil filter cap or that hose that goes into the intake, just above the oil filter cap). I checked the dipstick and it was bone dry. Did not hear knocking when I killed the engine, so maybe I am ok. Called the wife and she towed me back home with her HRR SS. I'll put some oil in it tomorrow and see where the leak is.
