Old Recall and TSB Number post
Old Jun 23, 2008 | 01:14 PM
  #151
New source for TSBs............
Enter specific info as to year, engine, etc.........
http://www.edmunds.com/maintenance/MaintenanceServlet
Old Jun 24, 2008 | 07:30 AM
  #152
Cokeybill's Avatar
As usual ChevyMgr comes up with the real goods Who ya' gonna call...(noy Ghostbusters) Thanks again...you the man
Old Jul 24, 2008 | 06:18 PM
  #153
camaro98z28's Avatar
Originally Posted by ChevyMgr
#PIP3932A: Transmission Fluid Leak Slipping Clutch Or Broken Axle Shaft - keywords crack housing shift slip - (Jul 21, 2008)
Subject: Transmission Fluid Leak, Slipping Clutch or Broken Axle Shaft
Models: 2005-2008 Chevrolet Cobalt SS
2008 Chevrolet HHR SS
2004-2007 Saturn Ion Redline
Equipped with a 5-Speed Manual Transmission (RPO MU3)
This PI was superseded to update models and model years. Please discard PIP3932.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers have commented about transmission oil in the clutch housing, slipping clutches or broken axle shafts on this model. An analysis of several of these failures has revealed that the problem is due to excessive front wheel hop during WOT acceleration events.
Excessive wheel hop transmits a torsional shock load into the transmission case. This causes the case to crack and transmission fluid to leak into the clutch housing. See photos below.
Attachment 3411
Attachment 3412
Attachment 3413
Recommendation/Instructions:
Stiffer axle shafts and hardware will change the system harmonics and help prevent wheel hop. These planned changes will not be available until the 2008 model year.
Note: Be advised that failures of this nature are abuse. They are NOT defects in materials or workmanship for which General Motors would be responsible and should not be covered under the terms of the new vehicle warranty. Vehicles with this complaint should be inspected by the dealer and Area Vehicle Manager. A product report should be submitted on each.
Talk about lets make something weak and blame the customer. Amazing
Old Aug 1, 2008 | 10:44 AM
  #154
ChevyMgr's Avatar
This PI (PIP3932A) was just re-released and now the HHR has been removed from it.
Old Aug 3, 2008 | 10:52 PM
  #155
XXL's Avatar
XXL
Is this because "Stiffer axle shafts and hardware will change the system harmonics and help prevent wheel hop. These planned changes will not be available until the 2008 model year" ... has been implemented in the HHR?
Old Aug 4, 2008 | 01:18 PM
  #156
ChevyMgr's Avatar
Your guess is as good as mine. Someone who works for GM would have to tell us why.
Old Aug 4, 2008 | 04:05 PM
  #157
Dreamwalker's Avatar
Dreamwalker
I have a 2006 HHR LT with the 2.4 and my check engine light keeps going on and off. The code that I am getting is P0011, has anyone encountered this problem before and what do I do to fix it?
Old Aug 4, 2008 | 05:55 PM
  #158
dandhcomputers's Avatar
This might help
http://www.engine-light-help.com/P00...ine-light.html
Check Engine Light Code P0011
Intake Cam Position Timing Over Advanced
Old Oct 1, 2008 | 09:56 PM
  #159
XXL's Avatar
XXL
Some customers may complain that they "still" do not like the normal operational characteristics of the OHB brake system AFTER the EBCM has been reprogrammed. This reprogram does enhance the feel of the OHB system significantly.
GM Engineering is working on developing an additional service repair for vehicles that the customers feel do not provide adequate brake assist after the calibration has been performed per TSB 08-05-22-001.
I love how the wording has been vetted by Legal so as to put the onus on owners for "not liking" the brake feel. Slimy bastages, all of them.
Old Nov 6, 2008 | 06:00 AM
  #160
Jeff®'s Avatar
Document ID: 2200465
So that's why it doesn't work. Because it doesn't
