Ooopsie BIG TIME!
Old Oct 17, 2008 | 08:43 AM
Digital_Rapture's Avatar
Exclamation Ooopsie BIG TIME!
Well I'm not sure what happened but I've lost power steering sometime between changing my interior lighting and my battery dying. I checked the manual several times for a fuse and I don't know if I'm overlooking it but I did not see anything on it... Not sure what to do from here. Sort of nervous about taking it into the shop!
Old Oct 17, 2008 | 08:49 AM
an08HHR's Avatar
Engine Compartment Fuse Block
Position #1. Electric Power Steering
It is a big 60 amp fuse
Old Oct 17, 2008 | 08:56 AM
Thanks You know just as I was about to delelte this I noticed that one blown after a visual check off all the fuses... feeling like a dumba$$ right now. But thank you!
Old Oct 17, 2008 | 09:03 AM
Jump start the HHR recently??
Old Oct 18, 2008 | 08:46 AM
Yes I think that's what may of caused it. Not sure what page I was looking on or If I just over looked it being hung over the other morning but it was the first fuse listed... I'm assuming this is common problem with jump starting...
Old Oct 18, 2008 | 08:55 AM
a76marine's Avatar
Especially if you aren't careful where you hook up the ground. There's a post that looks like it should be the ground but it's the power steering and blows that fuse.
Old Oct 18, 2008 | 09:15 AM
Bingo!
Old Oct 18, 2008 | 03:52 PM
Yonash's Avatar
so where do you ground it? for future reference, in case i eer need to jump mine. the label under the hood looks like it points to the strut mount for ground, but i'm not totally sure.
Old Oct 18, 2008 | 04:04 PM
That's exactly it!!
Old Oct 19, 2008 | 05:30 PM
Thank You! A lesson well learned! Talk about a Dee Dee Dee, ha!
oODeliveryManOo
Feb 7, 2016 10:06 AM
LA2112
May 4, 2013 08:37 PM
HillsdaleHHR
58
Apr 30, 2009 05:54 AM
masterchief1112
Jan 22, 2009 09:02 AM
Harpozep
Sep 13, 2007 05:43 AM
