Overheating Problems (Specially at night)
As I stated in my other post, coolant doesn't just disappear or evaporate. If you had to add some, it either leaked out or burned it out the tailpipe.
Also as donbrew noted, "good ole prestone" is the wrong coolant. Dexcool is what is GM says should be used in the HHR.
Others on this site have even posted about problems when using the wrong coolant.
With that being said, what would you say the next step for me is?
I agree with Firemangeorge, Anthony. You said you added to it in the summer and again in the fall, and then again 3 days ago. It is escaping somewhere. Not only that, but if it escaping, then there is also the potential that air could be entering the system, which could cause corrosion, and I think DexCool sludges with the introduction of air, doesn't it guys?
Added coolant 3 months ago. Added coolant again 3 days ago. That's twice you've added coolant. So wheres it going ?
My car is 6 years old. Never had to add coolant because I don't have any leaks.
I don't even have to add any to my 18 year old Dodge because it doesn't leak or burn it.
3 days is not long enough to say your's is not leaking
I get what you're saying, but I don't think you hear what I'm saying.
Fwiw. You should flush out that wrong coolant and refill with the correct Dexcool. I would also advise you replace the thermostat with an AC Delco one. I've been on this site a long time and have read numerous posts about folks having issues when using an off-brand thermostats.
Okay, so next step is flushing out the coolant and replacing it with Dexcool, is this a job that an intermediate person like myself could do? or should I take it to a mechanic?
Let me give you a little more of what I've done with this car and you can tell me if a flush is something I can handle, I changed the power steer motor, changed the term, and a lot a few other cosmetic things that I changed when I hit a deer back in 2014.
Thanks for all your help, every one here, thank you. I'm gonna update as soon as I figure out whats going on, and hopefully the flush does the job
If the prestone is mixed with DexCool in there, it may be a different answer to the question of if you can do it yourself. Also, find out where the coolant is escaping, because if air is getting in, that causes more problems. It could ruin the new DexCool you're going to put in.
You say you hit a deer in 2014? Hmmm. I wonder if that caused some damage to the radiator or ???
quote : "Let me give you a little more of what I've done with this car and you can tell me if a flush is something I can handle, I changed the power steer motor, changed the term, and a lot a few other cosmetic things that I changed when I hit a deer back in 2014."
Sorry. Don't know what a "term" is .
I just saw a few videos on radiator flushes, I think I am going to take it into my mechanic and have them check it out...I was trying to avoid that because money is really tight right now but I dont want to cause any permanent damage.
