But P0011 is more likely to be a by product of the bad VVT valves. A quick look at the chain won't hurt anything.
That’s why I suggest it, easier to see the chain and the front guide , confirm if there’s a problem or not, if not put the valve cover back on.
Originally Posted by Oldblue
(Post 896592)
Take off the valve cover, this is enough slack to justify replacing the timing chain, it is an easy job if you have a few tools and some mechanical skills. Cloyes offer great kits and are available through RockAuto, and they offer us a discount.
https://cimg7.ibsrv.net/gimg/www.che...73c7cfe4f.jpeg Order one of these front guide upper replacement bolts. https://cimg0.ibsrv.net/gimg/www.che...bc559fbf7.jpeg This was enough slack to trigger P0014 in my 2011 2.4 https://www.chevyhhr.net/forums/www....ad.php?t=60394 https://www.chevyhhr.net/forums/www....ad.php?t=61707 |
I just purchased the Cloyes 94201SAWP kit. Purchased through RockAuto with discount.
It comes with both chains, balance shaft sprockets, crankshaft sprockets,guides and the water pump. $175.00 Don't forget the melling guide bolt. |
Cloyes makes ACDelco.
Yes the Cloyes kits are preferred, available in different kits some with cam sprockets some without, depending on your engine and as mentioned with a water pump. We like to advise changing the water pump while the engine is apart for convenience, you’re gonna have dirty hands anyway, might as well do that now!
Thank you all so much!
