P0121 - intermittent
Old Jan 27, 2023 | 07:42 PM
Aj1968's Avatar
07 last 2.2l auto 288k car is bone stock. I get an intermittent code P0121 and was curious as to most likely causes. Any help is appreciated.
Old Jan 27, 2023 | 07:49 PM
It means that the throttle position sensor is ether disconnected or bad. Has anyone been messing around under the hood? Could be a loose connector, broken wire or bat throttle body.
Old Jan 27, 2023 | 07:59 PM
Aj1968's Avatar
P0121 - addendum
Yes, I had the thermostat done and had issues with the coils and plugs to them. A short while back I did get the code for a bad throttle body but had it cleared and it hasn’t come back. I will check tomorrow for wires, etc. Just curious, would a loose air box cause any of this? The bracket has been broken since I bought the car and I just got one to replace it. Thanks again.
Old Jan 27, 2023 | 08:01 PM
Isn't the TPS on the pedal?
Old Jan 27, 2023 | 09:03 PM
The actual sensor is in the TB. There are 2 circuits between the pedal (pedal position sensor) and the TB. The P0121 code looks for a difference between the 2 circuits and the computer's expected position.
You are thinking of the Pedal Position Sensor, the part that tells the computer where to position the throttle butterfly.
Old Jan 27, 2023 | 09:38 PM
Thanks for clarifying that
Old Jan 28, 2023 | 07:01 AM
https://www.obd-codes.com/p0121
Inspect the wire harness near the throttle body for chaffed wires.
Inspect the MAF sensor and throttle body connectors for bent pins , loose wires.
A loose air box can cause a loose wire connection to the MAF
Aj1968
Nov 25, 2022 01:36 AM
Rocket Dawg
Maintenance and Upkeep
24
May 31, 2022 06:27 AM
ENASNI TILLER
Jul 17, 2021 08:26 PM
LtGhost08
Jun 10, 2013 02:13 PM
chevyorange
North Pacific
Feb 24, 2012 12:10 AM
