2006 Sports Edition Pinstriping - NEED
I need the silver pinstriping going down the driver's side of my bright red 2006 HHR "Sports Edition"
The pinstripes for each side of the hood are still available from GM - and have been ordered
The remaining pinstripes for the car are indicated as 'Discontinued"
Part Numbers needed are:
15903337
15903338
15903339
Any ideas how I could do further search for source?
Thanks in advance for any help you can provide -
Ron F
St L, MO
15903337
15903338
15903339
Ron F
St L, MO
GM 15903338 Stripe, genuine OEM part
These three shops claim to have the 15903338
GM 15903339 Stripe, genuine OEM part
And these the 15903339
GM 15903337 Stripe, genuine OEM part
And these the 15903337
I’ve never dealt with this site, but at least you can try them.
My opinion, I wouldn't want to buy any GM OE pinstripes because of how old that stock would be. 15 years or so ? There has to be some kind of shelf life on the adhesive or the vinyl used.
There are many shops that can reproduce something like that.
I had the same thought but on the other hand acrylic adhesive is pretty stable and I have some 25 year old automotive vinyl tape that I still use successfully for odds and ends. You could add a little heat after application just for good measure.
This? https://www.chevyhhr.net/forums/gene...e2/#post354345
OldBlue / Hood stripes from Factory to be delivered today
The OEM Cats site does not allow direct checkout.
Diving into each shop that OEM Cats list reveals that each shop does not have any.
Will go the painting route.
