P0172 Code- Help Please
How did you reset the Fuel Trim and Alcohol content? I'm having the exact same symptoms in my wife's HHR. Already replaced both O2 sensors, Air Filter, EVAP Purge Valve, MAF sensor, and cleared the codes. Also ran some Fuel injector cleaner in the tank. Seems to be running better but the CEL keeps coming back on with the P0172 Code and has a heck of a time starting in the mornings.
The rubber tube from the air cleaner to the throttle body and the rubber hose from the valve cover to it.
And make sure it is tightly clamped to the throttle body.
Any air leak between the MAF and the #1 O2 sensor can cause trouble.
In the meantime, hold the pedal to the floor after the first crank or two, thereby placing it in flood clearing mode, i.e., zero fuel.
