P0449 code CEL on
cel on pulled code ( I have a 07 with 2.4 litre) it is P0449 something about a purge valve, tried to clear won't clear, would that be the carcoal canister bad?
Check the electrical connections to that thing mounted on the driver side of the engine under the air filter first.
PO449 = Evaporative emission control system: vent valve / solenoid circuit malfunction
Originally Posted by jtuchol
(Post 699457)
Good luck with it. Let us know how it goes. :thumb: |
thanks, I never used that search function before, it works!
