P0496
Old Apr 29, 2020 | 09:44 AM
New bifocals? I don't see P0466 I do see P0446 that was resolved.
Old Apr 29, 2020 | 10:26 AM
Thanks, not enough coffee yet!
Moot point because apparently it’s not returned.
Old Apr 30, 2020 | 02:29 PM
I installed the new AC Delco EVAP purge valve , I tested it for vacuum and pressure, both were zero on my gauge.
Old Apr 30, 2020 | 04:49 PM
The vacuum comes from the intake manifold, it sucks fumes from the tank.
Old Apr 30, 2020 | 06:13 PM
I know but when the valve is off the vehicle in your hand it’s supposed to be closed no air should pass through it either by vacuum from the engine side or pressure from the other side.
if there is air passing through it the computer reads an air leak when you start the car, if the intake can vacuum air through it.
Old May 1, 2020 | 04:34 PM
Ok, so I drove the HHR today , startup was crisp and quick , idle was smooth with no surging. I drove to gas station 12 miles away , fueled up then clicked the gas cap 3 clicks, start up was instant no bogging or sputtering.
I drove to Niagara Falls then to Fort Erie, shifts were smooth , no stumble at 40 mph, no sudden down shifts when lifting the throttle pedal.
When stopping for traffic lights , smooth idle and down shifts , no stumbling when applying the brakes.
I attribute these improvements to the EVAP purge valve, it is sealed and not leaking air and fuel vapours into the intake manifold or unmetered air flow. I also noticed the clicking noise was gone it sounded similar to a timing chain tensioner gone bad.
Old May 2, 2020 | 08:14 AM
PWM; the valve cycles rapidly to achieve a % duty cycle.
Old May 2, 2020 | 08:17 AM
But if it can’t close then it shows as a leak in the system
Old May 2, 2020 | 08:42 AM
Cat Man HHR's Avatar
Old May 2, 2020 | 09:38 AM
Precisely, only better pictures.
