P0621 Code
Old May 1, 2016 | 06:01 PM
Non OEM thermostats have been known to cause the P0128 code. But make sure what the code is supposed to be first.
Old May 1, 2016 | 06:02 PM
Originally Posted by Ktmrider
RJ - No. I think I got it at Autozone. Why? Should I replace it with an OEM?
Type "P0128" into the search box.
Old May 1, 2016 | 07:52 PM
Yes please , those aftermarket t stats are a known problem, because they don't heat up and open in the time frame the ECM is looking for.
There have been many threads about this in the past five years or so!
Also the issue of switching to green antifreeze and not staying with orange Dexcool!!
Old May 1, 2016 | 11:21 PM
Ktmrider's Avatar
Well I did use an aftermarket thermostat but I stayed with The orange stuff.
Old May 2, 2016 | 10:05 AM
K then just get the correct t stat.
http://www.jcwhitney.com/p3042205/sku-3503285.jcwx
Old May 4, 2016 | 08:57 AM
Ktmrider's Avatar
Thanks Oldblue. I did replace the alternator on Monday and the code went away. I ran the for 20 minutes on a test drive with my scanner plugged in and the code / battery light didn't come back on. However I will get a new OEM thermostat and replace the aftermarket one I put in last year. I think it was a half hour job at most.
Thanks for the help everyone.
Old May 4, 2016 | 09:14 AM
Great problem almost solved!
NxlKing2304
Feb 14, 2014 07:41 AM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
Sparky21440
Mar 26, 2011 08:41 PM
mr.bungle
Oct 9, 2006 11:10 PM
