p1174 -Fuel Trim Cylinder Balance
Old Apr 16, 2015 | 06:37 PM
  #31
novadude's Avatar
loss of oil was definetly possible,, lol, Forgot to mention that I had checked codes prior to our trip and had a P0302(misfire cyl 2) and when I pulled sparkplugs for inspection I found greyish deposits on the plug from #2 cyl, also I swapped coil pack from #2 to #1 and swapped plugs from 4 to 1 and vice versa, so i would have more to go on,, that may all be water under the bridge, dunno yet, i have photos of the plugs when i removed them, not sure how to upload unless i have to upload to photobucket first, car sure took a turn for the worse on this trip, anyway i will post back later after compression check, i really dont want to swap engines, i know its worse case scenario, hoping i can repair it leaving engine bolted in,, have to wait and see i guess, appreciate your knowledge and help Donbrew. I've been ASE certified on engine repair but let it lapse in 05, back then i still had a nice IT job, however that isnt the case anymore, got forced into early retirement, luckily i have a shop on my property and lots of tools,
Old Apr 16, 2015 | 06:45 PM
  #32
Originally Posted by novadude
i have photos of the plugs when i removed them, not sure how to upload unless i have to upload to photobucket first,,
Uh, do you see the links in my sig? If not SEARCH "how to post pictures", or scroll through the stickies in the "how-to" area. The instructions are not hiding!
Old Apr 17, 2015 | 12:49 AM
  #33
novadude's Avatar
umm now i do,
hope this works,,,
compression test shows
1-150
2-115
3-130
4-150
I am thinkin head gasket leakin, and it must be next to an oil passage,
when i had the car in the shop, nose was up a little, and it was smokin a lot,
hadnt been smokin very much on the highway, i remember when it died, it was goin uphill,, hmmmmm
Old Apr 17, 2015 | 05:46 AM
  #34
I had a look at those plugs, #2 has a problem , have you run Seafoam thru the engine yet?
While the issue could be the head gasket , seeing as your compression is lowest on #2 at 115 psi it could also be piston rings!
Just a thought, just a suggestion, just my prognosis !
Old Apr 17, 2015 | 06:55 AM
  #35
I had something like that going on a year or so ago. I burned 2 quarts of oil in a thousand miles. I decided a oil control ring was carboned up. I put an ounce or 2 of SeaFoam in each cylinder let sit over night, then burned down the road a few minutes. No more disappearing oil, I think I still have some carbon in one cylinder.
My compression showed 1 cylinder higher than it should have been.
Old Apr 17, 2015 | 11:38 AM
  #36
novadude's Avatar
Seems it Must be a ring problem since I have so much blow-by, it starts spewing as soon as I fire it up.. well, I have a can of seafoam,, worth a shot, "to be continued"
Old Apr 17, 2015 | 11:54 AM
  #37
We'll cross our fingers and hope for the best!!
Old Apr 17, 2015 | 12:43 PM
  #38
novadude's Avatar
If I had only 2 qts missing in 1K miles, I would be happy
I had recently picked up a 2nd vehicle just in case, so waiting for my dmv appt to get it registered,
so I will do the seafoam thing next week when the other vehicle is legal, follow-up here afterwords,
thanks for the tips guys,
Old Apr 17, 2015 | 04:50 PM
  #39
I fixed your pictures. You did not follow the tutorial fully.
Let me know what I can do to make it more understandable, please.
Old Apr 18, 2015 | 12:06 AM
  #40
novadude's Avatar
oops, what did i miss ?
