P1174 and then some
Old Sep 18, 2023 | 10:53 AM
jsfkz1's Avatar
Yea, I hope it something like that. Mine is the 2006 with cooler so hoping its not the cooler. I probably won't have have time to get into it until the weekend so I will hope for the best/
Old Sep 18, 2023 | 11:02 AM
jsfkz1's Avatar
Not a tech by no means and someone correct me if I am wrong, My trim values are staying around zero to plus 8 so it doesn't seem to be going to one exstream or the other as I would exspect in a close loop system trying to compensate for a bad feedback. I do industrial not automotive so if I am thinking about this wrong please correct me.
Old Sep 18, 2023 | 11:12 AM
PulpFriction's Avatar
2006 has extra-fine orifices, especially prone to clogging.
There is a thread here in which a member tried to find alternative injectors for that motor, with some success, if I remember correctly.
My trim values are staying around zero to plus 8...
That would be consistent with a couple of partially-clogged injects, for example; it tries going a little richer, but no improvement because now the cylinders with the clean injectors are burning too rich.
i'm not saying this is your problem, I'm saying with the age of that car, if it has the original injectors, it's bound to have a problem. No loss refreshing them, even if it doesn't solve the problem, and I suspect there's a good chance it will.
Old Sep 18, 2023 | 01:34 PM
jsfkz1's Avatar
Hopefully the injectors were replaced before I got it, The car had around 85,000 miles on it when I got it and is around 210,000 miles now. I won;t now until I pull them out
Old Oct 30, 2023 | 12:58 PM
jsfkz1's Avatar
Well, just give a update. I ordered my oil cooler seals from GM Parts Direct which turns out isn't GM at all but a dealership. Three weeks later I got my seals and installed. This has fixed the oil leak but I have now lost comms with the TCM. I not sure what's going
on here. I had unhooked the battery when removing the cooler and it sat for 3 weeks disconnected, top plug on ECM was also disconnected, The fun continues.
Old Oct 30, 2023 | 01:53 PM
Any progress with the P1174?
Old Oct 30, 2023 | 10:07 PM
You probably bent or pushed some connector pins out the back.
Why would you assume GM sells parts on the internet? Reading the home page tells you who you are dealing with.
Old Oct 30, 2023 | 10:40 PM
I've gotten some good deals and service from dealers peddling parts on the internet. Some will negotiate price, especially on old stock.
Old Oct 30, 2023 | 11:03 PM
jsfkz1's Avatar
Over looked it I'm sure
Old Oct 30, 2023 | 11:06 PM
jsfkz1's Avatar
PulpFriction,
No, car sat with cooler unhooked as I didn't think it would be that long to get parts in. Now that i have them it is turning off cold.
