p2261
Old Sep 23, 2012 | 09:31 AM
08SSREDHHR's Avatar
Question p2261
Car through a code so I hooked up Ezflash and it says P2261, Ive done research on here and everyone is saying stuck open BPV valve. I have the Forge one and I cant believe its stuck, its not that old. Do I need to grease it up now and then? Or could it be something else?
Side note: Car runs and boost fine.
Old Sep 23, 2012 | 11:49 AM
Which spring are you using in the forge valve? Might want to pull it out and check it for damage or breakage.
Old Sep 23, 2012 | 12:13 PM
08SSREDHHR's Avatar
Using the Green, Im suppose to get my 22psi tune next week and im gonna switch to yellow. But yea I pulled it out and checked over it and the piston on the forge felt a little stiff so I kept pushing on it and it feels alot better so im hoping that was the problem. I also checked all my vac lines, retightened all my charge piping and intercooler clamps. I put my hotside on last week so I wondered if had a small boost leak. So i cleared the codes and took it for a hard drive and got into boost a couple times and nothing has popped up.
andyb
Jul 2, 2014 03:16 PM
RodzHHRss
11
May 25, 2010 06:43 PM
