Panel lights issue
Old May 11, 2024 | 05:26 PM
Falequin's Avatar
Originally Posted by greg8453
You need to get an understanding of what happens with electronics. These are very simple to verify. Open and close the two wires and see what happens.
I'm not sure you tested anything correctly. Here's the fastest easiest way to test fuses using a meter or test light.
I'm well versed with electronics. I tested other fuses and got 12V. I tested the SWC fuse and got nothing. With the battery disconnected, I also tested all the fuses for continuity and they're all fine.
Old May 11, 2024 | 05:27 PM
Falequin's Avatar
In this case what I mean is that according to the schematic, the lights that I'm having trouble with are connected to that SWC fuse, so the fuse is an electrical point that should have 12V. It doesn't so I'm definitely not getting a 12V signal to these lights. I just don't know why.
Old May 11, 2024 | 10:45 PM
The 2A SWC fuse gets power from the dimmer on/off switch.
Old May 12, 2024 | 02:09 PM
greg8453's Avatar
Trace it back and see where you are losing it.
Old May 12, 2024 | 05:14 PM
Falequin's Avatar
Yes probably get to the body control module and trace it from there
Old May 25, 2024 | 06:51 PM
  #26
Falequin's Avatar
So... I found the issue. I was testing continuity on the fuses, going by the list in the diagram of the fuse panel under the hood, and I found fuse 69 was bad, Parking Lamps. Replaced it and I got the lights back. I guess I just missed this fuse.
Old May 26, 2024 | 07:24 AM
  #27
Thanks for your follow up!
Old May 28, 2024 | 03:11 PM
  #28
Did you fix whatever caused the fuse to blow?
Old May 28, 2024 | 06:09 PM
  #29
Falequin's Avatar
Originally Posted by donbrew
Did you fix whatever caysed the fuse to blow?
I think it was caused by me messing with that parking brake signal wire. Everything's been working fine since.
corivus
Jul 19, 2019 05:32 PM
esmarkey
Aug 19, 2017 08:45 PM
plovell66
Aug 4, 2016 07:07 PM
volcycle
Oct 12, 2008 08:34 PM
ballplr
Mar 12, 2008 07:43 PM
