peez help me! keys wont come out and radio wires are cold
Old Nov 29, 2008 | 10:45 PM
upzaw2000's Avatar
ok...
well today was just doing some normal car audio stuff and plugged everthing back in and....
radio wont start...
and it wont let my keys come out...
check many fuses, all ignition fuses that can be visually checked and the onstar/audio fuses. all are good.
please help!
Old Nov 29, 2008 | 10:48 PM
upzaw2000's Avatar
ps.
2006 2.4 liter
Old Nov 29, 2008 | 11:09 PM
DLVRNIT's Avatar
Check the owners manual for the stuck keys in the ignition! There is a small access panel just below the ignition switch on the bottom of the steering column! Remove the panel to access the manual release switch! Push the lever one way or the other to release the keys! Hope this helps!
Old Nov 29, 2008 | 11:10 PM
upzaw2000's Avatar
interesting.... ok i will do that right now
Old Nov 29, 2008 | 11:15 PM
JayKWills's Avatar
I have the same car. I haven't done anything to my car. but a few weeks ago I had a problem with my keys not coming out also. I took it to the dealer, he said it was the shifter, it seems that if the shifter gets any moister down inside such as coffee, soda,or even water from cleaning something happens to it and it wont let the keys release. They fixed it under warrentee. Did you try pushing the release button under the steering wheel for now?
Old Nov 29, 2008 | 11:25 PM
upzaw2000's Avatar
yap that just worked.... power wire for the radio is still reading .04 volts ut idk... im sure its all related in some wierd way....
im no noob to car audio at all... this has me stumped right now tho...
remote wire is hot, grounds are good.... power wire is cold...
edit: im gonna have to use the key release everytime for now
Old Nov 29, 2008 | 11:33 PM
DLVRNIT's Avatar
Yes the Key problem is kind of a Joke! I mean they know there is a design or engineering problem as noted in your owners manual and this is why they list a temporary solution of the access panel w/ the manual release lever! If that isn't a Crock of S#!+! Do take it to the dealer though ASAP so they can diagnose the problem! Glad to have helped !
Old Nov 29, 2008 | 11:44 PM
upzaw2000's Avatar
Thanx much guys, if they say anything bout my stereo i will just rig up my own power wire. lol 10 batts, about 10 watts of power, and 2 15's and lights and gadgets everywhere they may say i fukd myself with the stereo wire stuff. meh i dont really care bout that, id rather make them work tho lol
Old Nov 30, 2008 | 02:33 PM
upzaw2000's Avatar
well got up this morning and the fab isnt working, wont lock the doors, unlock, make alarm go off, nothing. EEEK!
Old Nov 30, 2008 | 02:46 PM
upzaw2000's Avatar
anyone know what fuse is for the autostart? the radio and amplifier fuses are good, i found the ignition fuse and it was blown, replaced it and the keys come out naturally.
radio still doesnt work and neither does the autostart/fab remote
