Please help, F23 trouble
This should fix all your issues, if the cables don’t fix it!
https://store.dfkitcar.com/products/...3-transmission
New cables didn't fix it, Made First to second shift really good and reverse. 3rd and 4th grind and 5th just isn't there for some reason. The cables are adjusted correctly, and everything is mounted correctly.
I got it to go into third once with double clutching.
🤷♂️ I bought the transmission so that will fix it.
I'm still trying to figure out how someone could drain the fluid then forget to refill it.
If the motor is off, can you shift all gears?
There have been a few instances of metal fatigue around the clutch pedal mounting to the point of not completely disengaging.
