Poor handling
They are on back order
https://www.turbotechracing.com/prod...idproduct=5148
you can send Aaron a PM
https://www.chevyhhr.net/forums/supp...swaybar-64351/
The bushings are 23mm, or the bar? I measured my bar before I ordered and it measured a freckle over 25mm, so that is what I ordered. Bushings seemed pretty snug when I installed them. Or was I supposed to order 23mm bushings, for a 25mm bar?
Thanks,
Thanks,
Door sticker should show 35 psi, but you can run a bit lower pressure, I’m experimenting at 33 psi, it’s a little better. 35 was to harsh with these Bridgestone tires.
Rear shocks probably have stickers. Struts might be identifiable too. You can get clues about springs from the paint color and sometimes they have a tag. Maybe post a side shot so we can see ride height, and measure each wheel from hub center the to top of the wheel well.
Depends on the model, year and wheel/tire combination from the factory. The sticker is for the factory installed equipment; if you change wheel size the pressure may change.
Yes, I’m aware of that, the 18” Cobalt SS and HHR SS rims are recommended to inflate to 32 psi
My 2007 with 16 inch wheels was 35 psi, my 2011 with 17 in rims is 35 psi.
most folks drop a lb or two for a more comfortable ride, it’s an individual preference, of course
