Power door lock problems
Old Feb 22, 2013 | 09:00 AM
jerry4155's Avatar
While this is my first time posting, I would like to thank the forum for the helpful information that I have seen here previously. I have a 2006 HHR that I have owned since new. For some time now, I have been struggling with power door lock issues. These problems started to surface shortly after my HHR pulled an engine light and code for a temperature issue that was eventually fixed by replacing the thermostat. While investigating the temperature issue I actually read somewhere that is that problem was not identified and repaired ASAP it could lead to door lock issues. Sure enough, it did. First, the passenger locks stopped working all together. Then the drivers side rear door. The drivers front door will still work but most of the time I have to hold the FOB in for a 1/2 minute or more to unlock the door. The FOB rarely locks that or any door. Batteries have been replace in both FOB's. Some info. on the web suggests that it is a BCM problem. Am I looking at replacing the BCM, or just reflashing the one I have. Any help on this matter would be greatly appreciated.............Jerry
Old Feb 22, 2013 | 11:32 PM
Hopefully someone will chime in on this.. IDK ?
Old Feb 23, 2013 | 08:24 PM
RBradley's Avatar
Have you had the fobs tested. Sometimes the battery is not the problem, the problem could easily be worn buttons or broken contacts at the battery.
Old Mar 12, 2013 | 10:22 AM
jerry4155's Avatar
No, I have not had the FOBS tested. They worked fine up to the cooling system engine service light coming on. Thanks.
jbbadboy
Jan 12, 2016 12:11 PM
Dandy Dave
Jun 27, 2014 11:21 AM
redbaron
Oct 14, 2011 07:51 AM
2010SilverIceSS
Jan 19, 2011 08:17 PM
hhrss09
Sep 13, 2009 06:58 PM
