Power Saving Mode now won’t start
Old Mar 8, 2019 | 10:04 PM
If you are under the hood at that fuse box, used to always recommend pressing down on all the fuses. Just for good measure.
Old Mar 24, 2019 | 01:12 PM
Eric Perryman's Avatar
2006 HHR Starting issues
Haven’t even tagged this thing yet and it’s keeping me very busy with repairs lol. Thursday my HHr was very slow to turn over to start. Friday morning went to take it to shop to get it looked at and was still turning over slowly but would not start . Popped the hood turned it over again and noticed some smoke coming from the bottom of the engine. Assuming it has something to with starting system but haven’t ever had a bad starter smoke it self. Any ideas? It’s 2.2 4 cylinder engine.
Old Mar 24, 2019 | 01:48 PM
My guess is the starter itself is toast - when they smoke it is not a good thing, and that is about the only thing down there that would cause problems like that.
Often the cause will be that the Oil Pressure Sending Unit on the front of the engine block, directly above the starter has started to leak and has gotten into the starter causing the problem.
Check out this thread that details replacing the Oil Pressure unit and the starter - https://www.chevyhhr.net/forums/how-...ng-unit-57962/
there was also a smell of burning plastic
Old Mar 24, 2019 | 02:48 PM
New starter time
Old Mar 24, 2019 | 03:01 PM
OMG! You let the magic smoke out!
Old Mar 24, 2019 | 03:37 PM
I’ll refrain from the Pope jokes!
Old Mar 24, 2019 | 04:22 PM
Cat Man HHR's Avatar
Yes, yes I've heard of this !
You need a vacuum pump, collect it and put it back in a bottle. Make sure to recycle by throwing the bottle in the ocean. I do believe in Jeannie.
Seriously
If the oil pressure switch above is leaking, It can drip on the starter and wet it down. If the positive battery cable has a loose or dirty connection, that can cause heat to let the oil burn causing smoke. Also a bad connection there can cause the engine to crank over slow.
Old Apr 1, 2019 | 12:35 PM
Field F Terminal Circuit Malfunction
2006 HHR 2.2 battery light on said check charging system. Battery Good car running okay got the attachment when pulled codes.
Old Apr 1, 2019 | 01:05 PM
Drove it 30 min home and zero performance issues at all. Could it just be nothing?
