Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
So I picked up a steering column from the junkyard today for $80. I think this is a 2010 (VIN 3GNDA13D56S677766). It is complete with steering wheel, air bag and power assist motor. It did not come with a key. The steering column with the key had active brake control, so I dont think it will work. I'll tear into it and see if I can remove the ignition module without a key, if so this might be pretty straight forward. I called a local locksmith and he said worst case bring the steering column and he could make a key for under $50. The locksmith says that if he has to call GM with the vin number, that GM charges $30 for the key code. He says he can do it without the key code. I do not understand this clockspring thing. This steering wheel is turned so , do I need to turn my wheels to match before I install the steering column or can I straighten the steering wheel while it is powered down?
"do I need to turn my wheels to match before I install the steering column or can I straighten the steering wheel while it is powered down?" - What steering wheel are you referring to?
Re: clock spring - In my mind, the best procedure to do would be to:
1) use the existing steering wheel to center the wheels
2) before installing the new steering column, complete with steering wheel, you will need to verify that the clockspring is at the middle position when the steering wheel is horizontal.
- this link might help - https://www.autozone.com/repairguide...96b43f80cb2e11
3) remove existing steering column, and install the replacement, making sure not to disturb the steering wheel and the clock spring alignment
Note: turning the steering wheel right now on the replacement column can likely break the clock spring, as there is likely nothing to stop the wheel at the end of it's designed limit
guppy's is a 2008, no matter what he thinks. in 2008 stability control was not standard. I thought that ABS was, 2006 ABS was optional, not sure about traction control.
