Power steering inop after Jump Start
Old Jun 13, 2010 | 10:00 AM
Rotor's Avatar
Hello,
I dont know if I have the same problem. But yesterday while jump starting my wife's car, I receiveed the power steering message. It was a very hot day and I was in teh garrage, after coming home from work (a 50mile drive, highway). I checked the fused and it is intact. I was tired, so i let it sit over night, I am going to check now.
Jumping should nto have hurt it, right? Figure the fuse would blow first, right?
Old Jun 13, 2010 | 10:13 AM
Rotor's Avatar
Nope went out today, and no message and no power steering. I put a code scanner on it and no codes came back. So, is the same issue?
Old Jun 14, 2010 | 09:41 AM
Rotor's Avatar
Anyone know if there is only one fuse for the EPS motor? All I see in the owners manual is a 2 amp fuse in the fusebox driverside center console. Does one of the relays in the underhood fuse box have anything to do with it?
Regards,
Rotor
Old Jun 14, 2010 | 12:12 PM
an08HHR's Avatar
Regards,
Rotor
Engine compartment fuse box. Fuse # 1. It will blow if not jump started correctly
If you don't have an owners manual, you can find an on-line manual at this thread https://www.chevyhhr.net/forums/general-hhr-4/online-owners-manual-3074/
Old Jun 14, 2010 | 02:52 PM
Rotor's Avatar
Regards,
Rotor
If you don't have an owners manual, you can find an on-line manual at this thread https://www.chevyhhr.net/forums/showthread.php?t=3074
I have an owners manual, somehow I missed that in the lower right hand corner . Thank you very much, I will ck it and repost.
Regards
Rotor
Old Jun 14, 2010 | 07:36 PM
Rotor's Avatar
an08HHR you are that is what is broke.
Anyways, I tried pulling it, yikes was scared to break it. So I tried pulling the ones next to it, same thing. So, is there a trick to these things or do I grab my vice-grips and pull? :)
Old Jun 15, 2010 | 12:44 PM
Rotor's Avatar
Okay all fixed up with 5.00 fuse. Thing was hard to come out, but I maybe a wimp, except judging how tight it was going in I may not be the problem. Eitherway, back to driving with one finger :)
Old Jun 15, 2010 | 12:57 PM
ChevyMgr's Avatar
Moved all posts from the power steering motor thread. This issue is not the same problem.
Old Jun 15, 2010 | 06:17 PM
Rotor's Avatar
You are correct, sorry for hijacking that one.
Old Jun 15, 2010 | 06:32 PM
ChevyMgr's Avatar
Glad you got it fixed and you are rolling down the road again.
cshaberts
Oct 11, 2020 05:17 PM
Timewalker
Jan 10, 2015 11:04 AM
hhr06NJ
Aug 25, 2014 09:58 PM
ImNewHere
May 27, 2014 11:05 PM
aloppen
Nov 13, 2011 03:01 PM
