Problems with the breaks on my HHR
Old Aug 3, 2019 | 08:55 PM
cmsharkey1's Avatar
Originally Posted by Lonwane
Did you bleed them to HHR specs (RR, LF, LR, RF) or the old way (furthest first, closest last)? There is a difference
We didn't. Would that cause the problem to happen some time later?
Old Aug 3, 2019 | 10:37 PM
There is a hose from the intake manifold to the brake booster. Make sure it is connected at both ends, no holes.
The check valve is the plastic part that the hose connects to on the booster end. It is supposed to allow air flow in one direction only.
Calipers slide, sometimes they stick. If the inner pads were worn much more than the outers is clue.
50% wear on the rears is way worn out. Adjustment is the question here though. The "self-adjusters" are not good enough.
Are there any warning lights or warnings that you are not mentioning?
You should get the OBD read, there could be some codes that do not cause a CEL.
Old Aug 5, 2019 | 09:04 PM
Maybe take it to a competent mechanic... Brakes are nothing to play with..
Old Aug 6, 2019 | 06:55 AM
aradmahogany's Avatar
Might be an issue with the abs module as well
Cat Man HHR
Mar 20, 2019 07:30 PM
jburton7379
Jan 7, 2011 10:52 AM
vschriver
Jun 13, 2008 07:57 AM
iowapk
Sep 20, 2007 09:36 AM
joesblackhhr
Oct 4, 2006 01:55 PM
