Puzzled
Old Oct 15, 2018 | 02:46 PM
Brian Spring's Avatar
Puzzled
I have 2006 2.4l with 130000 miles on it . So I changed the timing chain balancer chain and both tensioner and all guides. When finished car started right up sounds good. But now my t/c light is on and I have s hard shift. This was not present before i did the work. And after driving about 7 miles my check engin light came on with a p0171 code. Dont know if any or all is related to one another . Any one have suggestions were I can start looking for answers to these problems
Old Oct 15, 2018 | 03:25 PM
Cat Man HHR's Avatar
Read this, it's a start.
https://www.obd-codes.com/p0171
Old Oct 15, 2018 | 03:39 PM
The hard shift is a result of the P0171. You may have bumped something to cause a vac leak; like the PCV tube or any of the tubes connecting to the intake manifold. Or forgot the MAF connector.
Old Oct 15, 2018 | 03:46 PM
I will check for a vacuum leak. The maf is connected the flex pipe isnt cracked and it appears that all vacuum lines are in good shape but i will double check
Old Oct 15, 2018 | 04:16 PM
Up date
Cleared the code . Checked for vacuum leaks couldn't find any. The traction control light came on at idle but no check engine light. Reader codes again and have a p0171 pending code. Next step cleaning maf. I also checked all wires and connectors around all areas I was working in and didnt find anything broken or disconnected.
Old Oct 15, 2018 | 04:19 PM
It means that the #1 O2 sensor is sensing more oxygen than the computer think it is allowing into the combustion chamber. You might want to check the fuel pressure, it is possible for a bad fuel pump to cause it.
Old Oct 15, 2018 | 04:33 PM
Another up date.
Cleaned maf and car has been running for 20 mins no t/c light no check engine and no codes. Hopefully that's the fix
thank you everyone
Old Oct 15, 2018 | 05:50 PM
Fingers crossed! Enjoy the ride.
