Radio loses station memory
Old Feb 24, 2012 | 05:37 PM
ChevyMgr's Avatar
102.1 is the FM default setting. There is an AM default also, but I don't remember what it is. You really should test your battery as Sno White stated.
Old Feb 24, 2012 | 08:25 PM
BlackknighT's Avatar
Originally Posted by BlackknighT
When you start the vehicle isn't there a momentary lapse of power to most of the vehicle at that exact moment of cranking then restored again a split second later to the rest of the vehicle?
Us an amp meter on the battery to see if your starter is "starting" to crap out. It could be pulling a few hundred more amps then it should-causing a full draw to the starter with a momentary lapse of power to the rest of the vehicle, which also will kill a battery.
Don't you guys remember the old days when an amp meter (while testing a bad starter) would pin the RCH all the way to the right? (Family Forum-if you know what RCH is-laugh & keep it to yourself....)
Old Feb 25, 2012 | 08:25 AM
db/sb's Avatar
Some meters had different color 'CH's' ..........
Old Feb 25, 2012 | 01:50 PM
Old Feb 25, 2012 | 02:12 PM
Grizzly old man's Avatar
I have an '06 here. When I was having my problems {in this thread: https://www.chevyhhr.net/forums/audio-video-17/stereo-problems-36646/ } I had the radio out of the car for over a month. When I finally figured out it was the speakers and not the radio I put it back in everything was there the time, the station presets, even my equalizer settings, everything.
So I'm going with the onboard battery idea, at least for the Panasonic
6 disk changer unit in my buggy.
Old Feb 25, 2012 | 05:30 PM
db/sb's Avatar
I just opened up the OEM radio from our 06 (we changed it out for a later radio w/USB). There's no battery.
1900colt
Jul 21, 2014 06:09 PM
Bluegrass Boiler
Jan 20, 2012 10:39 AM
mgfred
Oct 14, 2009 10:05 PM
MWG2
Feb 21, 2009 08:33 PM
