Radio Problems
Radio Problems
I have a 2006 HHR. Sometimes, the radio display turns fuzzy. The radio keeps playing fine like nothings wrong, but the radio display is nothing but random green dots and senseless charcters. If I lightly hit the side of the console near the radio, the fuzz goes away and everything is back to normal.
Does anyone know what is wrong? Do I have a loose wire or ground? Do I need to replace the radio? Is there a past problem history like this for HHR radios?
Thank you
Thank you
Wiring is a possibility, but you may have the display in the head unit going bad. If a check of the wiring doesn't reveal any loose connections, that means you'll need to replace the head unit eventually. Fortunately they are fairly plentiful and relatively cheap, of course you could also use the opportunity to upgrade to a better aftermarket setup.
Hmmm. I've had the same "fuzzy" display on my 2010 a couple of times. Has been clear the last couple of weeks. If it would do it again I'll take it to the dealer for them to take a look. Post back what you find on yours.
@firemangeorge, I hope that you don't have this happen any more, but if you do and would like assistance with setting up an appointment please, let me know.
George
Yes Gregs, the display can be repaired if you can do without a radio for a few days to a week, here's a link to the folks I've used in the past. They do excellent work at very reasonable prices.
http://www.carradio.com/
