Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
I have been having trouble getting the driver's side rear blinker bulb to fit into the housing on my 2011 HHR. It looks like it's broken and will not lock in place. Does anyone know what I need to fix this?
Since it isn't locking, the bulb just sort of hangs in there and breaks just about every other day or so.
Housing where the bulb is supposed to fit in. It doesn’t lock in place.
such a misfortune happens if earlier, when replacing the lamp, you did not turn the cartridge all the way ...
As I understand it, in this case the bulb is located closer to the rear wall of the lamp, the plastic is weak there and this plastic melts. And if this happens, there is no going back. Each next lamp will destroy the fried plastic more and more.
I have this on my right headlight and am planning on replacing it.
Just be aware the aftermarket ones I purchased were horrible.Poor fit and cheap weatherstripping.I think I got them on Ebay. I ended up just polishing my old ones as they were just cloudy from UV damage.Also be careful not to drop one of the nuts or it may become entombed.
