I finally triumphed by inserting a prybar between the drum and backing plate while beating on the drum with the "bigger hammer". Be careful though, there is another bit of metal on the backing plate that you may get caught on.
Originally Posted by Lucky
(Post 739827)
If the drums wiggle on the the hubs then you may be stuck on the brake shoes. You may have to back the adjusters off to get the drums off.
(Post 739829)
If the drum is stuck at the hub, there will be no movement there when trying to take off the drum.
If only the shoes are holding it, there will be a little give and you should be able to see the hub is free. Over the years I've had to use a BFM(Big Frigging rubber Mallet) on many different types of drums. It's not just a HHR thing. drums do not seem to have any wiggle..I think they are stuck on axle..thanks |
