Chevy HHR Network
-   -   rear turn signals not working (https://www.chevyhhr.net/forums/problems-service-repairs-42/rear-turn-signals-not-working-48313/)
gondo Oct 28, 2013 11:47 AM
2010 hhr panel, last week one of the rear blinkers quit working, today the other one did too, i replaced the bulbs and they are still not working, BUT when i put it in reverse both new bulbs come on like they should, what am i missing? i tried to check all the fuses that could relate to those lights... however i never found a fuse in the manual that specifically states it is for the rear turn signals.... please HELP!!!!!!!
donbrew Oct 28, 2013 01:36 PM
Sounds like a ground wire problem. When your reverse lights come on it grounds the other light.
gondo Oct 28, 2013 02:28 PM
So where would you find the ground wire related to that? I gotta get this fixed it is my delivery vehicle for work!
donbrew Oct 28, 2013 03:29 PM
Those kind of problems are very time consuming and hard to do. Basically touch every wire from end to end and test every connection. Sorry.
Lucky Oct 28, 2013 04:44 PM
Do you have any aftermarket wiring to the tail lights like trailer towing or motorhome flat towing?
Snoopy Oct 28, 2013 04:59 PM
Question........
When you put in in reverse, your tail lights AND the reverse lights (white) came on??? So you had a red and a white light on from both sides. Did you also check for the brake lights?
gondo Oct 29, 2013 01:48 PM
no nothing, car is as stock as can be
gondo Oct 29, 2013 01:51 PM
Originally Posted by Snoopy (Post 723781)
Question........
Brake lights are not working either.
White reverse lights are the only thing working now.
gondo Oct 29, 2013 02:12 PM
yeah right i dont think so
whopper Oct 29, 2013 03:38 PM
Well, you are gonna have to get your hands dirty, or take it to a shop.
If you want to get your hands dirty, start checking the sockets for a good ground. If all the grounds check out, then you have a problem with connection(s) to power. And check all your fuses to the rear lights (check your owners manual for details).
