Rear View Mirror Mount Stuck
Old Oct 15, 2020 | 11:49 PM
Allen P's Avatar
Hey, I still havent managed to get my rear view mirror to snap back into the ball joint on the windshield mount despite already cracking my windshield in an attempt to do so without removing the mount first.
I've tried pulling the plastic piece upwards to slide it out of the metal mount glued to the windshield, but it simply refuses to come off (that was how the windshield cracked). Is there a way to force it out using little force, as I don't want to break the fixed windshield again, if not is there a way to heat fit the mirror back onto the ball joint?
Old Oct 16, 2020 | 07:50 AM
Did you remove the set screw?
See it here in the windshield mount shoe.
it is shown and explained in here.
https://www.cobaltss.net/forums/www....d.php?t=242002
Old Oct 16, 2020 | 07:52 AM
Allen P's Avatar
yes I did remove the screw,
does it slide out downwards or upwards?
Old Oct 16, 2020 | 07:54 AM
Upwards
Old Oct 16, 2020 | 07:56 AM
Allen P's Avatar
Upwards
It won't budge that's how I broke my windshield, is there another way like heating or sth?
Old Oct 16, 2020 | 08:06 AM
Not that I’m aware of , there must be some kind of adhesive applied in there by a PO.
Old Oct 16, 2020 | 08:13 AM
Just to be sure. You did remove that screw ?
If that's the screw you removed, then it's just stuck. Jiggle it a little side to side to unstick it, then it should slide up and off.
Worse case scenario. The previous owner may have glued it in place. If so, it may be hard to get off.
Old Oct 16, 2020 | 08:15 AM
Allen P's Avatar
Yes I removed that screw,
OK will try and get back.
Old Oct 16, 2020 | 08:52 AM
The adhesive used to stick the mount to the windshield is Super Glue, the solvent for Super Glue is acetone ( Old formula finger nail polish remover).
Old Oct 16, 2020 | 01:24 PM
Keep trying, gently
