Rear window switches for rolling down don't work easily
rolling up they work fine. rolling down, sometimes I have to press with 100000000 pounds of pressure
sometimes I have to push just right. rolling up works 100% of the time, with little effort Any ideas why this happens? |
no one?
Sometimes threads get buried, sorry it happened to you.
Give this thread a read, if cleaning the contacts doesn't solve the problem, you can find the complete switch assemblies fairly cheap online. https://www.chevyhhr.net/forums/problems-service-repairs-42/power-window-switch-46384/ |
Sounds like the contacts in the switch. I would replace the switch, and not even try cleaning the contacts, which would probably only be a temporary fix.
Could be the wording. The amount of pressure on a switch does not matter to the switch.
It does not matter how hard you kick a brick wall the wall still wins. |
