Recall didn't fix ignition problem?
Old Sep 15, 2014 | 04:37 AM
  #41
candyman93551's Avatar
Originally Posted by donbrew
Ground wire above driver side headlight on radiator support.
Connector to PCM locked down?
After that, I'm out.
The ground wire is secure.
Old Sep 15, 2014 | 05:04 AM
  #42
I checked this out. All wires are secure.
Old Sep 15, 2014 | 06:28 AM
  #43
LawDog88's Avatar
Originally Posted by candyman93551
There are no codes to clear, and there have not been any codes. When it is connected, it will warn me if there are any codes and will even let me know if there are any pending codes, but, there are no codes generated when this happens. I have even checked both pending and set codes and there are none. This is what I would expect though, because the cel only comes on when the engine shuts off (which it's supposed to do), and the cel goes off as soon as the engine comes back on. I wish there were codes because that might give me an idea of what's wrong.
To the highlighted portion... If that's a normal behavior, there will not be any codes. I notice this too, when I turn the key forward before starting, all my lights come up, and then it's just my CEL and "E-brake" (because I have a manual) lights that are left. And when I have accidentally stalled while taking off from a stop, the CEL is the only thing that comes on, but after I start, it goes away.......
Old Sep 15, 2014 | 08:24 PM
  #44
Snoopy's Avatar
I would think that 100 miles would be sufficient. Sorry it didn't work.
Old Sep 16, 2014 | 07:54 AM
  #45
Update: I went through with compressed air and a clean rag and cleaned a bunch of wires. I also noticed that the protective casing wasn't fully covering one wire, so I made sure it was fully covered. I didn't really expect any of that would fix it, but it appears that it did! It didn't act up at all yesterday! I want to thank everybody for your help and suggestions! I really appreciated all of your input!
Old Sep 19, 2014 | 10:50 PM
  #46
A wire or 2 probably are frayed/burnt and grounding out, probably near the exhaust.
Old Sep 26, 2014 | 04:54 AM
  #47
You pretty much got it! It started again, and I went through looking at the wires that I had previously cleaned. The ground connection (right by the main transmission plug) for one wire had come loose.
Old Sep 26, 2014 | 05:43 AM
  #48
Wow. Why didn't I think of that ?
Oh wait. I did. Back in post #28.
Old Sep 27, 2014 | 06:46 AM
  #49
firemangeorge "Your's appears to have a short or disruption in the electrical system. Where ? Hard to say. Just one of those things that will have to be traced down.
Me. I would look at it with the car idling and shake, pull, tap, knock, disturb and so forth, any wiring I could get my hands on." (from post 28)
I'm sorry. I did see your post, and I should have acknowledged it as well. You and Donbrew both realized that it was probably a short. You also had a great suggestion (shaking all the wires with the engine running), and I had planned on doing just that, but then it stopped acting up, and when it did return, it was much more rare (2 - 3 times a day, as opposed to at least 50 to 100). But, there were only a few wires that I had cleaned before that got it to stop for a few days, so I looked closer at them, and that is how I found it.
I do want to thank you, donbrew, LawDog88, Snoopy, and everyone else for your help. It was a royal pain having to drive it like that, and I'm so relieved that it's now fixed.
shybull
GM Recall Campaigns
43
Dec 22, 2014 10:02 AM
frustrated
Oct 30, 2014 03:53 PM
anniehhr
Sep 14, 2014 12:57 PM
pipilo
GM Recall Campaigns
May 12, 2014 06:19 PM
