Remote engine start ?!
Hello from POLAND!
Just bought HHR 2.4 LT 2006 , swiped from Chrysler PT Cruiser, HHr is awsome.:thumb: But i have a problem, today i entered the personal menu it says Remote engine start: on but my pilot dosn't work after i push lock an imidetly the start option engine dont start. I find this option superb for polish climate, can You help me ? Sorry for my english that not my native |
Welcome to the site, if there is a check engine light the remote start work.
It could also be the battery in the FOB |
Welcome!
Does the fob unlock/lock the doors? Is "AP3" listed on the sticker on your glove box door" You must press lock 2 times then RS. Any engine fault codes will inhibit RS. Hood open/unlatched will inhibit RS. There is a switch in the hood latch that sometimes gets misaligned or broken. An online Owner Manual is available through the link in my signature. |
FOB ?! Im not so good in english
Check engine is particulary alwys on i have lpg in my HHR Ive pressed lock two times and it didnt start the engine after that. About AP3 i cant check it right now its 15 km away from my home getting adusted to my needs, optical tuning is on :) Codes... there are only 8 hhrs in polnad so if i drive to computer chcec i doubt they will even a program for that :) |
Originally Posted by M3ndoR
(Post 827383)
Check engine is particulary alwys on i have lpg in my HHR Ive pressed lock two times and it didnt start the engine after that. About AP3 i cant check it right now its 15 km away from my home getting adusted to my needs, optical tuning is on :) Codes... there are only 8 hhrs in polnad so if i drive to computer chcec i doubt they will even a program for that :) As to reading the codes, all cars now have OBDII and use the same kind of scanner. |
(Post 827383)
Check engine is particulary alwys on i have lpg in my HHR Ive pressed lock two times and it didnt start the engine after that. About AP3 i cant check it right now its 15 km away from my home getting adusted to my needs, optical tuning is on :) Codes... there are only 8 hhrs in polnad so if i drive to computer chcec i doubt they will even a program for that :) So you are saying that your HHR runs on propane? The codes donbrew mentioned have to do with the 'check engine light'. So if your 'check engine light' is on, the remote start will not work |
Just in case you're not pressing the correct sequence of the FOB buttons
The sensors and computer are calibrated for gasoline, whoever modified it for propane skipped that step. So the check engine light is on. Remote start will not work if the check engine light is on.
A fob is that thing with the remote control buttons on it. |
FOB = PILOT = REMOTE CONTROL (like in tv) :smile:
So i i wll have to calibrate it for LPG wit LAMBDA swap. But nevertheless You suggest that when my check engine is not lighten up the remote start should work ?
(Post 827389)
Welcome!
So you are saying that your HHR runs on propane? The codes donbrew mentioned have to do with the 'check engine light'. So if your 'check engine light' is on, the remote start will not work EDIT 24/07/2017 TODAY THE FOB battery died |
hello
im on the starting engine from remote thin again. Does anyboudy have a sheme of car eletrics responsible for this option ? I think that the guy that insalleged the LPG cut wired the REMOTE ENGINE START thing to keep the LPG runnig. So i have go by the wiring diagram to see where he made the modyfication so my electrician can plug the LPG on other place. The check engine and the hood adjar is not showing on the dashboard anymore I think that he made a mestake someware over here https://images84.fotosik.pl/723/7bbb6ce8c791fcaagen.jpg https://www.fotosik.pl/zdjecie/7bbb6ce8c791fcaa |
