rhondasb1
Old Aug 21, 2014 | 07:36 PM
rhondasb1's Avatar
Unhappy rhondasb1
Hello to everyone. I have a 2007 Chevy HHR and just recently had a new ignition put in for a recall. About 1 month later my key wont come out of it.
I took in today to Chevy dealer and they said I need a shifter replaced which will be $360. to have this done. I'm really upset about this I was wondering if anyone else out there has experienced this, and what have you done. I would really appreciate any help with this. Thanks,
rhonda
Old Aug 21, 2014 | 08:22 PM
Lucky's Avatar
Welcome to the site
We have had a few members with this problem. If it's a shifter problem there is a bypass to release the key in the mean time until repairs can be made.
Use the search bar at the top of the page and type in key stuck and you will pull up lots of threads on this then you can match up you systems.
Here is a short video of the bypass release.
Old Aug 22, 2014 | 07:44 AM
cj krause's Avatar
and aboard
Greetings from Texas
Old Aug 22, 2014 | 10:26 AM
Welcome to the site, Dorman has a repair kit for this shifter issue!!
Old Aug 22, 2014 | 12:35 PM
and to clarify: the Ignition recall has nothing to do with the shifter problem causing the ignition key to jam - they are totally unrelated. So don't blame the recall or the dealer for it. Blame it on unfortunate timing. Keep us posted on how it goes if you can.
Old Aug 22, 2014 | 01:10 PM
Well, one of the 2 possible issues. The plunger pin, not the solenoid.
My solenoid was fixed with a shot of WD40.
Old Aug 22, 2014 | 06:19 PM
True Don, two possible fixes both a lot less than $360.00 bucks!!
