Roof Rack
Thule roof rack
I have Thule roof racks installed and use them for carrying windsurfer or kayak. They are pretty stable and look good with the factory rack. I'll try to post a picture.
Here is a link for the Thule HHR Racks
Eli
Eli
Originally Posted by coolsurf
My surf bud, just got a blue HHR with the crome package and also the factory cross bars. They look pretty good.
I've been away for 10 days.... what else have I missed?
I have seen pics of the factory crossbars, but weren't too impressed with them. They looked like they were pretty wide, which would prevent my Thule accessories from clipping to them.
We have over 900 members here, does anyone have these yet? Or even the Thule/Yakima crossbars? I would like to see pics if you do. My vacation is coming up and I need something to carry my kayak. If I had know that the factory rails were so cheap then i wouldn't have gotten them. Good looks only go so far.
-Saint
-Saint
Removal of Factory Roof Rails
Hi
I am rather new as I have only had my HHR for about a month but I am trying to modify a set of Chevy Venture Van Cross Rails to fit on my HHR.
The problem is I have not figured out how to remove factory roof rails enough to slip the venture cross rails into the horizontal slot. I removed the screws on the underside but I can't remove the long bar. I don't want to go inside and start removing the headliner. Is there anyone out there that has worked on the factory roof rails. I have spoken with my dealer and they can order the GM Cross rails but I think they sit too high and plus they are close to $300. Thanks for any help.
Factory Roof Rails
I just thought I would ask again.
Does anyone have any experience with removing the factory side roof rails? I am trying to modify a set of Chevy Venture Cross Rails to fit into the Factory Side Rails but I need to be able to separate the two pieces in order to slide the Venture Rail into the slot. Just wondering with this many members someone must have some experiences. I have removed the screws on the bottom of each rail. Can the end chrome caps be removed from up above?
John
John
John
John
The roof is thin, but seems to hold my 9'3" surfboard. The end caps come off by lifting up on the end then sliding outwards. On mine there is a torks bolt and a hex bolt on each corner. They use a nutsert to hold the rack on. If you want to carry bicycles you can install the trailer hitch and then get the bicycle rack that slides into the receiver, that way it not rubbing on the paint.
Hope this helps.
Hope this helps.
