Running Board Problem
Old Jul 18, 2007 | 07:22 PM
  #51
courthousedeb's Avatar
According to the dealer, the pads are not glued down. They have tabs that fit into the running boards in various places. Apparently there are 3 different versions...all just a little dirrerent.
1. Factory boards that came with the car painted to match.
2. After factory boards that came painted to match, but were made slightly different and required a different pad than the factory boards. (These are the ones that are on "SMOKE" now)
3. After factory boards that come only unpainted and need to be done by the dealer or whoever they use for their paint work. These apparently are different yet from #1 & #2 above and have yet another configuration and pad than the other two.
Not sure what the deal is with Retroburban's boards. I suppose it's possible that there was a set laying around in Sport Metallic Red and they decided to ship those. Definitely a mind boggling thing when it comes to these boards.
Old Jul 19, 2007 | 04:58 PM
  #52
johnbrum's Avatar
biggest thing about paint and why they have you come in is so that they can match it perfectly, not just the paint code. there are varients
Old Aug 1, 2007 | 05:22 PM
  #53
Bertland's Avatar
Got both of mine replace on warranty early June this year, the new one are doing the same, want to the dealership today, they order some other, eventually GM will surely do something to correct that, Hope!!
Old Aug 1, 2007 | 06:27 PM
  #54
OK...got Smoke back from the dealer with his new boards and he thinks he's pretty special. The new ones look great and the pads appear to be thinner than the ones I had before. We'll see how they hold up. Here's some pics I took after I picked him up.
Old Aug 6, 2007 | 01:26 PM
  #55
johnbrum's Avatar
Having mine replaced now as well the weather in dallas is getting hotter so the drivers side started to lift in two places. The dealer said that a couple of the clips had broken so they are ordering the pad for me.
Old Aug 6, 2007 | 01:30 PM
  #56
FEAR1HHR's Avatar
Thumbs up
Originally Posted by Navyflyer11
How about these from Truckshop.com
or these
That's what I have on mine & totally cool & happy with it.
Old Aug 6, 2007 | 03:55 PM
  #57
Bertland's Avatar
I will like to install those but I use LilRed in winter, not sure they will like the salt treatment....
By the way, could you show pics from your installation, I will like to see if I can swich them for mine, and go back to OEM one for winter....
Old Aug 13, 2007 | 09:13 PM
  #58
FEAR1HHR's Avatar
Sorry I don't have picture's as they were installed for me. But I'm sure you could switch back & fourth if you like. I don't for see that as being that hard of a problem. But I def. understand on your salt concerned.
Old Aug 14, 2007 | 08:52 PM
  #59
Bertland's Avatar
Thank's, I will check with my dealer to see hpw it install, they will change them shortly
Old Aug 14, 2007 | 08:55 PM
  #60
karen1953's Avatar
I like the # 2 bds, goes kind of with my flames. Must check into those.
Thanks.
Dennis Puskar
Sep 20, 2012 10:30 PM
VictorySpark08
Jan 10, 2009 12:27 PM
SSROADSTER
Apr 26, 2008 01:50 PM
blackout
Jul 20, 2006 11:16 PM
