SEL and P0010 code
Old Sep 29, 2011 | 11:10 AM
ChevyMgr's Avatar
Originally Posted by richflstn
Mine just went past the 36,000 mile warrnty and now the CEL is on nd off pulled codes P0010 and P0011. Now I'm stuck footing the bill
Wher should I start first. Surges at idle and under a light load?
Why wouldn't you take it to a dealer and have it fixed for free? If it is the solenoids it's powertrain.
Old Sep 29, 2011 | 02:24 PM
@richflstn, how many miles out of the 36,000 miles are you?
Old Sep 29, 2011 | 03:22 PM
diskullman's Avatar
Dealer stated solenoid was an external engine part and not covered under warranty, but claimed GM has had a lot of problems with the solenoids. Claimed it was NOT covered under warranty, but he was being nice and covered it anyway.
Old Sep 29, 2011 | 03:24 PM
diskullman's Avatar
Originally Posted by JoeR
Brad, likely a P0010 DTC, camshaft position actuator.
Prolly gummed up from Amsoil....
Dude, you could put my USED oil on your salad.
Old Sep 29, 2011 | 03:55 PM
@diskullman, thank you for the update. I am glad to read that the dealership is taking care of this for you.
Old Sep 29, 2011 | 04:28 PM
ChevyMgr's Avatar
Your dealership is WRONG.
See post #2 (this comes straight out of the GM web site)
https://www.chevyhhr.net/forums/problems-service-repairs-42/07-09-10-11-powertrain-parts-coverage-list-22231/
You my friend need a new dealer.
Old Sep 29, 2011 | 05:30 PM
jay loukakis's Avatar
Originally Posted by ChevyMgr
That's not a good code number. You are short one number. If you can update the code so I can update the thread title so others doing a search can find this thread.
Which fuse?
Good question to ask.
Technically fine print should be smaller than regular print.
All's well that ends well.
The big print giveit and the small print taketh away.
Old Sep 29, 2011 | 06:23 PM
JoeR's Avatar
Dude, I like a fine quality balsamic vinegar and Mobil 1 on my salads!
Old Sep 29, 2011 | 06:47 PM
Why get mad - it's a machine, and machine break on occasion, just like us. Anyways, first check your oil level, and change it if it has a lot of miles on that oil. If the problem still continues, it's a relatively easy fix if you have a few hand tools, and have half an hour or so of spare time - https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
Or like ChevyMgr says - do the dealer thing if they will do it for free.
You can reset the CEL and the hard shifting condition, by disconnecting the NEGATIVE battery terminal under the trunk floor and reconnecting it.
Old Sep 30, 2011 | 01:00 PM
richflstn's Avatar
Michelle,it has 40,600. This morning the ABS light and CEL
are on. Took it to the dealer,waiting for a call. I have owned several GM
vehicles, this is the first one I have had issues with.
