Which sensor is this?
P0131 HO2S Circuit Low Voltage Sensor 1
Anyone know what sensor this is on an 09 SS? Thanks Allex |
That is the upstream sensor. The one closest to the exhaust manifold
Originally Posted by ballplr
(Post 586944)
Later Allex |
The upstream sensor controls fueling. IDK about the 2nd code, but fueling issues are bad ju-ju. Stuff can happen that is not entirely predictable. Get 'er done. Fix that, and then see if you still have issues. That might be all.
Thanks guys. I'm getting the upstream O2 changed out today or tomorrow at the latest. Hopefully that'll cure the other hiccup; if not I'll keep you all posted.
Later Allex |
You might want to just check and clean the connection for the sensor - they can cause similar problems to what you are seeing. Might save some $'s rather than replacing it. But if you are under warranty, let the dealer take care of it. :)
Originally Posted by whopper
(Post 587176)
Later Allex |
These thing can drive you nuts for sure. I originally was referring to the o2 sensor connector, which is probably a pain to get to. The reason I mentioned it was that I had. Similar problem with a Dodge Avenger throwing o2 codes, so I unplugged and replugged it several times hoping that would be enough to clean it. It ran great for several months then started throwing codes again. I then cleaned it with electrical cleaner and used a dental pick to get deep into the connection, then repacked it with silicone grease to keep out moisture. That was about 4 years ago and it hasn't skipped a beat since.
Good Luck and keep us posted |
