Service ECS & power steering
Old May 30, 2025 | 08:35 PM
Overkillcustoms's Avatar
MOOG RK620898 and MOOG RK620897
lower arms.
If the LCA were the problem why didn't it pop up until after the inner tierods were changed?
Old May 31, 2025 | 04:35 AM
PulpFriction's Avatar
lower arms.
For a couple possible reasons, but it doesn't matter. Moot point, Those are the incorrect lower control arms with the incorrect ball joints that have been already discussed. They will ruin your hard-to-find knuckles, as well as cause alignment problems. The good news is that in addition to the correct LCA's and ball joints (as mentioned by Oldblue,) the SS knuckles are now available from ZZP. But hopefully you can salvage your knuckles.
Scan for codes again and find (and write down) the C code(s).
Old May 31, 2025 | 06:28 AM
Wrong LCA’s.
Look up the MOOG website fitment chart for those part numbers you listed. It shows both Cobalt and HHR models 2005-2011. It does not list the HHR SS.
Pretty sure that MOOG has never had LCA’s for the HHR SS.
As stated many times on this forum, when it pertains to parts lists for the HHR SS, most lists are incorrect or wrong.
Last edited by firemangeorge; May 31, 2025 at 09:40 AM. Reason: Spellcheck was wrong again
Old May 31, 2025 | 07:11 AM
Control arms , note select the 20.5 mm for LNF SS HHR.
https://zzperformance.com/products/z...m-control-arms
Or just replace the ball joints again select the 20.5 size
https://zzperformance.com/products/z...ball-joint-kit
It might not have shown until the knuckles loosened up. If your knuckles are damaged, they are available once again
https://zzperformance.com/products/z...ering-knuckles
Old May 31, 2025 | 08:31 AM
Ill have to check if I still have my old LCAs. The came from Ohio and had a lot if corrosion on the knuckles. They were cleaned up as much as possible.
I will scan the code again to see what it says.
I can always return these arms and get the right ones. But I dont see how changing the arms out would let the steering work again. I dont want to throw money away.
Old May 31, 2025 | 08:59 AM
Doesn't matter if it has any effect on steering. It is dangerous to operate the vehicle with those undersized ball joints.
Old May 31, 2025 | 09:06 AM
Originally Posted by donbrew
And that would be easy to do with the wrong LCAs. Impossible to make the toe stick.
The Cxxxx code would tell you what the problem is. There are no Cxxxx codes that have anything to do with "communication".
code U2111
Old May 31, 2025 | 09:11 AM
Here are the codes
Old May 31, 2025 | 09:19 AM
jimvw's Avatar
I installed a set of LCA's and the went in just fine. After driving a few months, the front tires were worn out on the inside edge (nothing left of the tread) and an alignment showed they were way off. it drove OK, I ended up replacing the LCA's a second time with Moog brand LCA's. alignment was back on and I had to purchase new tires, Moral is, be careful where you buy the LCA's. if the price is cheap, they may be too. I stick to name brand replacement parts now.
Old May 31, 2025 | 09:58 AM
A. none of those are Cxxx codes.
B. U2111 should have a hex number after to tell which module (like those Bxxxx have) Basically the steering control system.
C. ALL of those Bxxxx codes pertain to the airbag system, why didn't you mention the airbag light? Specifically one or more elements are disconnected/unpowered.
I suspect someone broke or disconnected a wire while working on the car.
jimvw, as repeatedly stated the SS control arms are NOT the same as LS/LT arms, no matter what a parts book thinks. Almost all books (including GM dealers) claim "fits all".
