Service Engine Soon / Oxygen Sensor
I had the SES light come on this morning after I started my HHR. Seemed to run fine. Took it to the dealership to find out what was going on and was told that my #2 oxygen sensor was detached.
My question is, has anyone ever had this simply come unplugged before? The dealership told me that if reattaching it doesn't fix it, it will have to be replaced for approx $400 including labour. That seems a bit much. |
Check your owners manual I think the emissions are under warranty for 8 years.My 96 astro was 8 years or 130,000 KM had one go at 128,000 and got it for free and put it in myself.If you can change a spark plug you can do it your self.
Originally Posted by Enthusiast
(Post 352565)
No! Did you just get some service done or did you get an oil change recently? Those connectors don't just fall off the sensor. |
Originally Posted by GTOMIKE
(Post 352579)
Originally Posted by ChevyMgr
(Post 352585)
(Post 352579)
Thought I would use this existing thread to comment and pose a question. Comment: the plug takes GREAT effort to disconnect, what with tabs and interlocks, so I agree with ChevyMgr that it is virtually impossible for it to disconnect on its own. Now my question: how long does a sensor last and perform at 100%? I have mine out and on the exterior shell there is a coating of deposits but all the "vents" are clear. I have 25,000 miles on it.
(Post 352769)
Unfortunately my emissions are under the same 3 yr / 60000km warranty as everything else. A little disappointing.
| All times are GMT -5. The time now is 12:44 AM. |
