Service ESC + Service Traction + lock icon appearing on dashboard
Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Multiple unrelated codes, smells like a bad battery. I've seen this too many times. And it's the easiest thing to start with. As said above, 12.3 volts is a bad battery. In my experience anything lower than 12.6 is bad. After it sits for 10 minutes or more with the engine off, put a multi-meter on the battery at the posts.
It measure at 12.6 . I will try a different battery today.
I took out the battery from our Dodge Grand Caravan which measured 12.9 volt sitting ... and put it in the HHR. It doesn't fit in the tray but the cabled attached to it without any bindings.
Still doing the same thing however I didn't notice it before but now I am seeing my dashboard needle dancing around and the fuel gauge keep going from full to low fuel back and forth. The readout would read low fuel then stop and also readout service esc and the security lock amber light come on .. also traction off etc.
The dashboard doesn't seem to be acting up anymore and stable .. however now the traction light comes on with ABS and red "Brake" light .. I guess I am narrowing it down to hub sensors now?
does anyone know the resistance reading for the hub sensors on ohmmeters? I want to check it all before going to buy a hub and determine which one is bad one
Just check for continuity.-The larger of the 2 modules in front of the fuse box is the ECM the other is the TCM, the big one with brake fluid tubes is the EBCM.
What 2 ground wires? The large red wire on the side of the fuse box is BATT and the smaller is the power steering.
Another thing to check is the bundle of wires that run to the ECM, we have heard of oil migrating UP the bundle and getting into the connector.
i disconnected the two connector from the ECM and spray clean it .. I don't see any oils on it .. it look clean
One connector was a pain to disconnect with ABS module barely blocking the latch to disconnect it but I managed to disconnect and reconnect without removing ABS module
Look like problem shows up with it very hot outside and goes away when it cool like during night time .. not sure ...
