"Service Traction" & "Service Esc"
2008 Auto LT2 won't start with key - won't attempt to turn motor.
The messages are
"Service Traction" appearing for a few seconds followed by "Service Esc"
Wednesday, drove it, temp was -27C.
Friday, it won't evn turn over. Temperature did drop down to -35 in the meantime but today it has warmed up to -25C.
Is there any way to reboot - like disconnecting the batery. (Have warmed the battery.)
The messages are
Neither message should make the engine not turn over, but a low voltage battery will set those codes. The ebcm is the most power consuming module on the vehicle and when the voltage gets low it triggers the codes.
I notice the TPMS now displaying an error - not reading any pressure. Probably those batteries now. When it warms up I'll check again.
bad03xtreme
Mar 11, 2010 05:15 PM
JonyyB
Jul 7, 2006 07:24 AM
