Shifter interloc switch?
Old Feb 14, 2016 | 06:59 AM
Radco's Avatar
I assume that what it is called , Anyway I am referring to the transmission safety lock on the brake pedal that let the Shifter out of drive. When it is freezing out I have to step on the brake a few times so I can move the shifter! The other day it was a tad cooler like 6 deg F and it was a real booger to move! Stepped on and off the pedal several time then all was fine ! I am assuming that the safety switch is sticking? I had that happen on my service van a few years ago I believe! SO what is your 2 cents? Am I on the right track ? Anyone know the part #?
2011 Auto 2.2. Ignition switch changed for the recall!(no issue )
Thanks Rich
Old Feb 14, 2016 | 07:12 AM
I remember some prior postings that said a good shot of WD40 will usually free up a sticking shifter interlock.
Old Feb 14, 2016 | 07:19 AM
Radco's Avatar
George I was just letting anyone know that my tranny was on a 2011 HHR 2.2 just in case it made a difference and also noted that the ignition switch was changed ,!
Thanks for the advice on the WD I have a couple cans laying around
Old Feb 14, 2016 | 08:19 AM
The solenoid is on the shifter. You may be able to get it fixed under extended warranty, if they can make it happen at the shop.
The only part is the entire shifter.
Use the search term "shifter stuck", this is a common problem.
Give the switch a little shot of spray lube, have a paper towel ready to catch any overspray and drips
Keep warm!
Old Feb 14, 2016 | 08:32 AM
Radco's Avatar
The 2011's only came with the 2.2 or 2.4. The 2.0 was the SS engine, 08-10.
George the 2.0 was a typo I do not always proof read lol I fixed in :)
Old Feb 14, 2016 | 08:34 AM
Radco's Avatar
Don I was wondering if it may be covered! I will call the dealer this week! Thanks for the heads up
Old Feb 14, 2016 | 08:35 AM
Radco's Avatar
Keep warm!
Blue I have oil spill pads to catch the drips :) Plus I will use the garage at the shop :) First I will call the dealer first to see if it may be covered Thanks
How you doing? Been awhile since I posted
Old Feb 14, 2016 | 10:14 AM
Still struggling with the chest area problems since OHS in July 2014, but holding on! Thanks for asking, and you, Rich? I haven't seen you on here in awhile, you ok?
Old Feb 14, 2016 | 11:44 AM
Radco's Avatar
hanging in, Back injury will be forcing me out of work soon, but could be worse! :) Ill be 63 soon so I think it's time to hang up my hat! On the plus sie my son Adam won his 5th MMA fight,now 5 and 0 Amateur welter weight, so I am pretty happy :)
Here is a you tube link to the fight if your interested! This is the first time NEF streamed a fight so it isn't great, sound cuts out but video is good,, the mark starts w/Ruben and I need to figure out how to adjust the start time to when Adam show up. Adam is in the Red corner
Cell phone video. Not great but you get the idea of what's going on :)
https://www.youtube.com/watch?featur...3e0cQM#t=16871
