Slow Tire Pressure Leak and Fix
Old Jan 31, 2008 | 08:36 PM
c2vette's Avatar
My local tire technician solved an annoying problem I was having with losing about 2 psi/day in one tire. Turns out the tire bar code label on the bead (of all the dumb places to put a label) caused a discontinuity in the bead that was allowing a very small leak. The label is bonded or vulcanized to the bead and cannot be removed, so we had to wet-sand it down smooth. Perfect now, no leak. Side discovery is that the pressure sending units in each wheel are VERY accurate. I figured this was worth a post since all the SS tires (maybe others too?) apparently have the barcode label on the bead, and this was a heck of a thing to isolate.
Old Jan 31, 2008 | 08:48 PM
tireman1554's Avatar
Thats been a problem for as long as I can remember. Michelin and Goodyear more than others. Yes that thing is a real ***** to remove but can be removed. At one of my recent round table discussions with Goodyear that was an issue that was on the table. Anytime we mount a new tire that has that barcode on the bead area, my techs know to remove it.
Old Apr 6, 2009 | 07:53 AM
stephenm's Avatar
I stopped by a different dealership, and was talking to them about installing the stage kit, and mentioned how my tire was losing air when the temp. dropped.
They said they would take a look at it,
They inspected, tanked it, and spent about 90 minutes on it.
they said the valve stem was loose, I haven't had a problem since
Old Apr 7, 2009 | 12:02 PM
lake's Avatar
slow leak
I am having this very promblem-the dealer can't find a slow leak-yet I have to put air in once a week. My question is where or what is the bead.
Lake
08 2lt
Old Apr 7, 2009 | 02:42 PM
09 Panel's Avatar
The bead is the part of the tire that sits against the rim and forms the seal of the tire to the rim.
Old Apr 7, 2009 | 02:56 PM
davidjb's Avatar
Thank You, I have this problem on my left front.
Old Apr 7, 2009 | 08:33 PM
GoFast's Avatar
I had this problem, also. After the second time bringing it in to the dealer the Service Manager pulled up a TSB from '03 about aluminum wheels and slow leaks. He completed the TSB and ended up replacing all 4 wheels. The new wheels haven't leaked so all good now.
Old Apr 8, 2009 | 12:56 AM
Snoopy's Avatar
You have a very astute Service Manager. Most would not have thought about that particular problem (which by the way, has been around for years). Porosity of alloy wheels and a proper interior sealing is the solution. I am surprised, however, that he REPLACED all the wheels. But, good for you
Old Apr 8, 2009 | 08:17 AM
pitbull76's Avatar
I had a slow leak in one tire, and it was a simple fix. It had a small nail in it and I just hadn't seen it.
Old Apr 15, 2009 | 10:13 PM
c2vette's Avatar
Just an update from my original post, my RF is now having a slow leak again. I am at 23,000 miles and the tires are probably good for 35,000, so I guess I'll have it looked at since pumping it up 4 lbs every week is getting annoying.
